MSI has a nice overclock Genie that I am using but I am skeptical. this would be my first time trying to manually overclock my CPU, Memory and motherboard.
At the bottom of the Control Center it says Overclock/Overvoltage
CPU Ratio x7
Base Clock(MHz) 215 MHz
CPU Voltage 1.4035V
CPU NB 1.3895
SB Voltage 1.0992V
NB Voltage 1.0992V
DRAM Voltage 1.6517V
MSI MB 970A-G43 (MS-7693)
CPU AMD FX 8320 eight Core (At the moment its running at 1500 MHz x7.0 BC 215.0MHz and 125 W.
MEMORY 8x2 16gig G.Skill F3-1866C9-8GXM
At the moment is running at DDR3-1333(667MHz)
What can I do to make my timings better? Thank you for the reply back. Thanks for being patient with me.
CPU Ratio x7
CPU Voltage 1.4035V
CPU NB 1.3895
SB Voltage 1.0992V
NB Voltage 1.0992V
