I wouldn't touch a Corsair water cooler for love or money. They have a horrible recorsd of problems and failure.. and the new H100i and H80i are definitely sticking their hoses between their legs and doing the RMA waltz back to dealers. If you want CLC there are others that have a good track record... but not Corsair.
Thermaltake Water 2.0 works great (and so did my h100 for the record). As far as air coolers, bang for you buck - Hyper 212+ Evo. That will take a 2500K to 4.5Ghz+ depending on the CPU.
Doyll - you have been on and on about the H100i being a failure... can you PM me some links on that?
The Noctua NH-L12 doesn't cover the PCIe slot if installed in the correct orientation. Thermalright AXP-100 and Prolimatech Samuel 17 should also do the job.
PCI slot cover doesn't actually matter in my project anymore, and on a re jig I need a shorter cooler. I do like the look of both of those suggestions. Doesn't this look good....
The project is probably going to be filled scythe slipstreams anyway.
