madcow235 said:Silver is second to only diamond and graphite in conductivity
This makes me want to try powdered pencil lead mixed with silicone grease (or AS Ceramique). I wonder how it would turn out.
every review I see artic ceramique is cooler the AS5.
Silversinksam said:
Thats because ever review you have read that shows Ceramique beating Arctic Silver 5 is flawed and wrong.
The reviewers forgot to allow 200 hours or more to let the Arctic Silver 5 reach optimum performance. (Arctic Silver 5 temps will drop 2-5*celcius after 200 or more hours.
Those reviews you read have the facts all wrong, that or they did not have the patience to wait the required time..
During the system's initial use, the heat from the CPU lowers the viscosity of the compound to enhance the filling of the microscopic valleys and ensure a minimum bond line between the heatsink and the CPU core. Then the compound thickens slightly over the next 100 to 300 hours of use to its final consistency designed for long-term stability.
Only a very small amount of Arctic Silver is needed on small CPU cores like Intel P3s and AMDs. Transfer about 1/2 the size of an uncooked grain of short-grain white rice or 1/4 of a BB for small core CPUs.
germanjulian said:
what the hell is a BB. baked bean?
rofl dont think so cause thats a lot.
Agent_Mull said:oh, i want some diamond paste. They can make artificial diamonds in labs, so it wouldnt be too expensive.
larrymoencurly said:Silver, copper, and even aluminum will probably work better than a silicone-based grease (IMO)
I thought that all thermal pastes used either silicone-based or ester-based grease and mixed in heat-conductive powders, like silver or zinc oxide.
BTW, I found that an ohm meter doesn't measure electrical conductivity reliably because when I stuck the probes into some paste designed to conduct electricity, the meter read infinite ohms.
ChillPhatCat said:
it will just act like there is a perfect connection between the core and the HS.
arabarabian said:As far as thermal conducting capabilities copper is one of the better materials out there but it still does not match or come near silver. It is cheap enough to get Artic Silver so don't bother trying to find copper grease, if they make it.
Daniel
But just b/c its a copper hs doesnt mean that it cant dissipate the heat. I could have a copper plate and it wouldnt cool as good as my slk-700. just as if i had a diamond block, it wouldnt cool as well as an dlk-700(i made that up. d=diamond ).ChillPhatCat said:
No point unless you have a diamond heatsink... If your grease is better than the heatsink, you've still only got a copper heatsink... it will just act like there is a perfect connection between the core and the HS.
Holly mother of resurrection.
Where did you get copper grease?
