Hey Guys,
I wanted to share some results I experienced disabling "Core Parking" in Windows 7 64bit.
I was getting some mild stutter and performance drops with Planet Side 2 and decided to investigate.
I came across a couple for posts from other AMD users and it was suggested to disable the "Core Parking" in Windows 7 or us the MS patch.
Decided to give it a shot and It made a very positive improvement.
I gained about 8-10 FPS !
You can find lots of info on the web on how to disable it, or download a program to do it.
On a side note, the FX MS patch don't work on the 8350.
Using the 12.11 Cat drivers btw.....
