- Jul 23, 2004
- Alta Loma Calif.
thanks coolest i use nothing but core temp and speed fan thanks for all your work
Rich
Rich
Is there a way to run CoreTemp in Vista WITHOUT turning off the UAC AND aslo NOT see that nag screen??
Z
EDIT::: I found the cure. Seems its another Vista nag screen to find and disable. all is well now but the Core Temp icon has this shield on it indicating it needs admin premissions. WHAT A MESS.
This is currently in a very early development. I've been working on this for the last couple of days.
If anyone ever saw PerfMonitor by Franck (CPU-z), then the idea came from his work, and he has helped me out a bit on several points.
The graph is resizable. I still need to work a little bit on the efficiency of this thing but it's looking good right now.
All colors are customizable:
Background
Text color
Graph color
Grid color
Frame color (yellow in the pics)
0° graph (not shown in the pics)
Title text (up to 30 chars)
Do let me know what you think.
Art,
That is a great new features there, thanks.
Suggestion :
Lets Microsoft Perfomance Monitor to do the charting & logging stuff, but make the coretemp capable of running as a service instead of a program, so it can be really handy for logging and other triggered events in various automation in handling cpu temperature related issue.
The Coolest said:I think the graph is now as optimized as it'll ever be.
Public beta testing will soon begin.
Updates on the progress can be seen here:
http://www.alcpu.com/forums/viewtopic.php?t=422
I'm considering that.
I'm not sure if this is what you're getting at, but some way of logging temperatures and vcore etc. to disk would be really useful for diagnosing crashes. The only problem is that you need to have logged the details soon before you crash, which means you'd have to write to disk pretty frequently. Does that make sense?Art,
Suggestion :
ya can do i will PM you when i get it running on the 9th.Oh!
A register dump file + a screenshot at idle and full load would be great!
If you have an IM that'd be even more awesome
Regarding the E7200, Core Temp wasn't reading the 45nm voltage correctly untill 0.99 The fix is mentioned in the change log.
