- Jul 29, 2001
I'm very new at monitoring hardware and came across this nice program to check the temperature on my CPU.
How do I know if my laptop's CPU is running at an optimum temperature?
CPUID = 0x6E8
APICID = 0
Revision = C0
Processor = Intel Core Duo ULV L2400 (Yonah DC)
Frequency = 1064.00MHz (133.00 x 8.0)
Platform = Socket 479
VID = 0.9750v
Tj. Max = 100 C
Core 0 = 67 C 11%load
Core 1 65 C 9%load
Thanks in advance.
The Coolest said:I'm starting to build a plugin engine for Core Temp.
Besides shared memory, which allows developers to create their own standalone applications, plugin capability in Core Temp would mean that a user can install plugins into Core Temp to add new features and functionality.
As the most simple example, "Core Temp Grapher" will be converted into a plugin, meaning users will be able to have it as an integral part of Core Temp without the need of running an extra standalone program.
Plugins are very useful in that anyone can easily extend the usability or functionality of an application, as the interface to the host is usually an open standard.
This also makes the application modular, meaning that replacing or updating code will be as easy as replacing a DLL file in a directory.
I'm really excited about this and hope I can make this happen soon.
What do you guys think?
Source
I'd really like some feedback. I think people with some developer's knowledge would probably see why this is a great addition. Extending functionality without actually touching a single line of code in the main executable.
And to other news...
A new version - 0.99.1 will soon hit public beta.
It adds support for new CPUs like Nehalem, Atom, the new 45W AMD K8s.
There are a few bug fixes and some new features and changes, mostly GUI related.
All the settings were finally moved to the ini file. The only thing that remains in the registry is the option to start Core Temp with windows. (no way around that)
got one that runs in linux? im just asking, im looking down the road for some atoms to run linux. wonder if you are still going to have a plugin for network cpu temp monitoring that would be cool. for the people with FAH/seti farms in their house.
temps look normal to me, laptops run hot by nature. i saw one intel based one running 80c under load. the mac mini using intel mobile parts was running closer to 90c.
Version 0.99.2 - 18th August, 2008
- Fix: Start with Windows option was broken in 0.99.1.
- Fix: Default color for the second system tray icon is invisible with WinXP blue theme.
- Fix: Save screenshot function would create a corrupted BMP in some viewing software.
- Fix: Nehalem does not report VID like earlier CPUs. VID field now disabled for Nehalem.
- Fix: Incorrect 65nm Turion X2 code name detection.
- Fix: Potential bug of improper K10 and up recognition.
- Fix: Enabling distance to Tj.Max with "Highest temp." for system tray would show the largest distance to Tj.Max instead of smallest.
- Fix: Vendor ID and Device ID values were reversed in the register dump file.
- Fix: 3/4 temperatures logged for Phenom X3/X4 instead of 1.
- Add: Support for Core Temp plugins. (Still in beta phase and not in GUI yet).
- Add: Full support for AMD's Puma platform CPUs (in previous version reffered to as Griffin).
- Add: Initial support for 45nm AMD processors.
- Add: Update K8 and K10 recognition code to support all currently known CPUs.
- Add: Default TDP detection for Nehalem.
- Add: On the fly CPU speed detection.
- Add: Close to system tray option.
- Change: Log file is now produced in CSV format - easily import your logs into Excel.
- Change: Logging interval is now in Seconds instead of miliseconds.
- Change: Default logging interval is now 10 seconds.
- Change: Logging is now off by default.
Hey man thanks for all your hard work, but I really have just decided to stick with RealTemp. Would have expected your new version to show the same TJmax on my e8500 as realtemp.
this guy is a machine, i tell you what!
