- Jul 22, 2005
The diodes being read here are uncalibrated in AMD cores. AMD claims +/-14C without calibration and AFAIK, there is no calibration method.
davidk21770 said:The diodes being read here are uncalibrated in AMD cores. AMD claims +/-14C without calibration and AFAIK, there is no calibration method.
ochungry said:RT, the speedfan would also show the CoreTemp highest reading.
Speedfan shows 3 temp reading for mine- the #1, and #2 readings are what everest or MBM5 shows for Core 1 &2, and the #3 reading is so called the diod reading same as CoreTemp reading. I take this utility w/ a grain of salt and just use it to monitor the highest core temp. The way I justify this utility is to use it as a safe measure and set CoreTemp reading as my highest limit when i stress test. Another word if I am priming, I observe this cortemp to know when to stop the test. I stop when coretemp reaches 57c, even if MBM5 or everest show 45-47c. You never know wich utility is closer to actual core temp. Add both, the high (coretemp) and the low (everest, MBM5 etc) and take the average of the 2, might be more meaningful.
BTE, those pic you sent me look awesome. Looks like you got the temp under control w/ that AMD heatpipe and extra fans.
davidk21770 said:My understanding is that the BIOS reads yet a 3rd temp sensor and this is the sensor reported by all of the motherboard monitor programs that don't go out and read them directly (the only 2 that will do that that I know of right now are the latest version of everest and this program). (This 3rd sensor IS calibrated). Since the BIOS does not execute idle cycles, it'll read high and can not be compared to the value in windows. MBM5, SpeedFan, Everest, etc. should all read the same unless they are adding a scale or offset to the BIOS readings (calibration factors can be added in both programs -- the calibration added by MB manufacturers is not necessarily that precise). The 3 speed fan readings are not these diodes. They are most likely your CPU, your MB, and your chipset.
The Coolest said:My article which discusses motherboard temperature sensors and DTS has been posted just now here:
http://www.overclockers.com/articles1378
The Coolest said:I updated the first post with the article link and a "Digg it" link so to increase Core Temp popularity. so please click on it and digg it:
http://digg.com/hardware/Dual_Core_CPU_Temps_a_program_to_monitor_EACH_core
IIRC - Mine will show the temp if you hover over the tray icon ...watchthisspace said:Will there be a possibility for when you minimize it to Tray instead of having the little white window thing, it will show the temp, so you don't have to click on it to find out what it is??
It Would be a good idea to have an option for user to calibrate the temp. another word, a way to increase or decrease the reading similar to MBM5. This way the user can adjust the reading according to some form of calibration. Those who remove the IHS and install a temp sensor on the core can adjust the CoreTemp according to the probe.The Coolest said:I'm working on adding a feature to show temps in the systemtray.
