- May 22, 2011
- USA
Well I wouldn't think that's the problem since I did it with the other card, honestly I think I just want to grab another evga classified 590, the dell one is ridiculous technology wise. It overuses clock speed compared to the EVGA one, during idle mainly. But I don't know. I feel like the card itself may be the issue.
Jack, I'm on break and just finished black belt testing, got me my 1st degree yay! So that means I have time and I will do it. It's a D5 Vario.
Rollie, I'll flush the block afterwards and make sure contact is good enough, if it happens again, bye bye Dell 590
Thanks for updating your signature instead of running around looking for the past info that might have been changed by now. Makes it much easier for us.
So you have the pump at setting 5. You could leave it at that or the lowest I would go is setting 4. All up to you really.
Yes, I would take apart the loop and grab that 590 out and redo the block with new TIM and pads etc.
Grats on your black belt.
