Didn't expect these many responses lol.
To answer questions, some with backstories, in paragraph long responses...
The card that is having high temps is the infamous card of 2 years who overheated like a mofo turning down that wished 607 mhz clock speed sometimes downward to the 400s for the sake of temperature control. I want to rule out that the card itself is the issue however I can't be too sure about since this same issue happened with an Alphacool block. I like the ideas surrounding that it COULD be a bubble, but that sounds like it would be rare, considering this system has been running ~60 hours non continuous, however I rocked it back and forth <10 times about to a 45 degree angle.
Also Jack, is that in the stickies anywhere? "Rad dancing" a water block? I probably crossed about it but it's probably in there as "cleaning" your block.
Jack has the right to be mad at newbies imo. Seasoned veterans can get annoyed at anything a newbie does wrong, hey, they pay attention and know their stuff, I can't argue. I admit I am lazy and I did want to finish, I mean I haven't touched an MMORPG in almost 4 months now, withdrawal is starting to kick in. The lazy part kicks in where I underestimated this science and had an Alphacool water block thinking it'd cool itself(Lol!) but that was 4 months ago, if I planned and wasn't lazy, things would be a lot better, but I didn't know this was a subject to be taken seriously(considering all the things to be bought, considered(scientifically), etc.) until again, 4 months ago.
Moving on back to water cooling...
What I think(it may be wrong) is that something is preventing solid contact between the block and the card itself. In my eyes, a flow issue is unlikely, but could be a factor, that would be my last resort of where to think.
Hey! I could be wrong for all I know, I just want to get through all the simple things before deconstructing my loop because that is time consuming and time, at this moment is not an abundance. I have my driving test tomorrow and final black belt testing on Friday and Saturday, so AT THIS TIME, I am focusing on the little things before deconstructing the loop altogether. I have a feeling it will be happening to troubleshoot the error but NOW is not the time.
Pitch troubleshooting ideas, but please, don't expect me to do them immediately and then move on to something else. That's what I'm seeing, multiple methods of troubleshooting then response after response, you guys seem to rule them out and move on to complex methods when I haven't done simple ones yet. I may have misunderstood what you guys are trying to do, but hey, I'm voicing what I think.
I'll reiterate what is going on with the whole loop, once more.
Sorry I use the term GPU, as the core itself within the card and as the actual graphics card, I'll try to be more clear this time.
Cool card(Top 590) is getting regular dual GPU idle temps at 24-28, each GPU, on the card, varying through ambient temps. Flow doesn't seem like an issue considering deltas and fan speed, which is running in a quiet state, about 30-50%.
Hot card(Bottom 590) is getting temps that are weird. One GPU on the card is usually 8-10 degrees hotter than the other. Ex. GPU 1 on the card, 44 C, GPU 2 on the card, 36 C.
And at idle that is fairly common, hitting max clock speeds, not at full load, they EXPONENTIALLY rise in temps, but in the same range of 8-10 degrees. HOWEVER, under GPU benchmarks, these suckers almost hit 100 C in sync after 5 seconds of Heaven(Unigine that is lol). I'm just rambling on about what has happened in my experince with these and it's probably not helping anything and just is extraneous words for you guys to read.
Moving on...
One thing I know for sure is once I first started this loop up, on of the GPUs hit 45 C at an all time LOW. Second/third time I booted up, that same GPU dropped 5 C. After I removed the washers from the backplate and tightened the screws to the point of still keeping that card in tact(not physically bending/damaging), it dropped, you guessed it, another 5 C. Since then, nothing has really happened. Ok, reevaluating myself now, it COULD be bubbles, for the first time, I could've moved bubbles the second time when I was tightening screws. WHO KNOWS? It could be contact with the block and the card, WHO REALLY KNOWS? All in all, without proper sentence structure/organization(hello, laziness strikes again Jack)...
TL;DR:
Bubbles can be an issue, I'm not the best at priming my system.
I don't have time for all this deconstruction for my loop, AT THIS TIME.
Let's rule out the simple things, ONCE I DO THEM FIRST.
I'll fix that goddamn fitting if I have to rebuild the loop, I don't want it to be a priority.
CONTACT CAN ALWAYS BE A POSSIBILITY. When the Alphacool was taken off, there was little TIM contact, only a few spots scattered across.
Misc things:
HI ZOINKS, love your build log, happy to see some support over here for this clumsy(water cooling specific) white child.
I was about to go to sleep, instead I got to write for 40 minutes, lovely.
Moral of the story:
NOBODY IS PERFECT! It's not possible to be perfect, everyone has their flaws, especially me.
Finally:
Sorry for the long rant, vent, whatever you'd call it.
