- Apr 16, 2011
- Missouri
So I recently bought the PC-O11 Dynamic PCMR version. I plan on using a 360 aio on the side. I also plan on using 3 intake on the bottom and 3 exhaust on the top. My motherboard only has 12v RGB headers and was wondering could I use the Corsair Commander Pro with regular 4 pin pwm fans untill I get a board that supports ARGB? If not, is there a fan hub you can recommend?
