- May 22, 2011
- Greece
Hello guys I'm back.
So I finally bought the gigabyte gtx 770 but my psu(corsair vx 550) couldn't run it so I'm looking at other options.
I'm already over my inital budget, so money matters. I won't be going for one that can support sli in the future or anything like that.
Options then:
56 euros: Corsair VS 650: Bottom of the line Corsair psu, 3 years warranty, 50amps on 12v rail, barely off the 80+certification(85% maximum efficiency I think).
57 euros: XFX Pro Series 550w: Good quality psu, 5 years warranty, 44amps on 12v rail, 80+ bronze,
Coolermaster GX 550w: Available used for 10 euros less, around 3.5 years of warranty remain(5 year total), 44amps on 12 v rail, 80+ bronze. CM psus get bad reputation for some reason, but 5 year warranty can't lie.
So I wanna be able to easily run and maybe OC even further the gigabyte gtx 770. I also want to O/C the cpu(i5 3570k) close to 4.5 ghz.
Quiet operation is important. It's hot over here(Greece) and my psu sometimes goes crazy in the middle of the night, while I'm trying to game.
Do you think the 6 extra 12v rail amps on the VS 650 will be worth the 2 year less warrany and no 80+ certification?
Will I be perfectly fine with the XFX and enjoy the 5 year warranty, 80+bronze and better quality overall?
Or should I just save some money and get the coolermaster?
If I ever upgrade it will be for a maxwell chip which will probably consume less power. I'm thinking that the gtx 770 wants 42 amps on the 12v rail. It is making me a bit uncomfortable that the XFX and CM can only provide 2 more than that. Any OC will make the margin even smaller. Am I being paranoid?
I guess bottom line is, is it worth getting the slightly less quality+efficiency psu to get the 6 more amps?
system specs from my profile:
Gigabyte GA-Z77x-D3H, i5 3570k, Sapphire 6950 2gb(trying to get the gtx 770 in there), Corsair Vengeance 8gb 1600mz, Kingston HyperX 240gb, WD Caviar Blue 1TB, Corsair VX 550W
Thanks in advance.
Options then:
Thanks in advance.
