- Jan 13, 2005
Ok so I am trying to wrap my head around this one. Long story short I am trying to set up a computer in my IT storage area since there are no computer up there for general use and I am getting tired of stairs.
We rely on donations for computer hardware so none of it is very....new, keep that in mind when I mention the following.
we got 2 Dell precision 690's in a few weeks back, these are dual CPU boards with one cpu socket populated per tower, only one 15k hard drive between the 2 of them and they were next in line to get working. Upon closer inspection one of them had a bank of bad caps around the memory so that's an automatic write off so I harvested it for what I could (CPU/RAM) and thought I might as well populate the other working tower with what I pulled and get rid of the husk.
it posts fine, no ram errors or any thing but it will not boot into windows already installed, windows install discs or USB drives, (Pro or LTSB) each one gives "MULTIPROCESSOR_CONFIGURATION_NOT_SUPPORTED"
I double and triple checked in the bios to make sure they were the same make/model/speed between one another and sure enough:
Intel Xeon 5150 @ 2.66Ghz 1333Mhz Bus, 4MB cache, Dual Core
the only difference, stepping:
CPU0 06FB
CPU1 06F6
I couldn't imagine a stepping change would cause a no boot problem but who knows, whats your take?
CPU0 06FB
CPU1 06F6
