- Jul 28, 2013
- Fredericksburg, VA
Hey guys -
I'm looking for a CPU cooler that will let me run my i5 2500k somewhere between 4.5GHz and 5GHz at reasonable temps... I've been doing some reading and keep seeing the Hyper 212 EVO mentioned, but I've also seen that it often causes problems with RAM slots... I'm running the i5 2500k CPU on an MSI P67a-GD65 motherboard with 16GB (4x4) of Gskill Ripjaws RAM, and a Radeon HD6950, so all of my RAM slots are in use, and I don't want to have to sacrifice one (or more) of them to make room for a CPU cooler. I also figured that (based off of what I've read), a push/pull configuration on the Hyper 212 would work best, which leaves me even less room to play with...
Alternatively, I've been looking at Corsair's H50/60/80/etc line of sealed liquid coolers... I'm certainly not opposed to a liquid setup, but from what I've read, they aren't too much better than most air coolers until you move up to the H100, which my case simply won't handle.
Sooo... My ramblings aside, and given my setup, could you guys recommend me some CPU cooling options? I'd prefer to stay under $100 right now, but I'm open to hear anything you've got. Thanks guys!
