Hi!
I have i7-4790k. I wanted to overclock it after a few years and found out that my temps are very weird under 100% load. Checked for both prime95 and intel burner. My Core 0 gets almost instantly to 100 degrees and Core 1 to around 90 while the others stay at good temp. I did replace thermal paste and checked my voltage settings aswell as if cooler is running correctly (be quiet! Shadow Rock Slim). I know my cooler is not the best, but I am sure it shouldn't cause 30 degree temp differences between cores. I am quite out of ideas and don't know what to do anymore. I have found a few threads with almost exactly the same issue across the internet, but no real answer was found.
I also checked temps in programs like hwinfo and core temp. The same everywhere. Also under lower load Core 0 doesn't go to 100 degrees and on idle it looks very good as well.
I think it is not a processor's fault, but I can't be sure anymore. If anyone had issue like that and managed to fix it? Or have any good ideas I would appreciate it a lot.
Thanks!
Thanks!
