Hi guys.. ive been surfing around trying to find a solution.. and the www has brought me here..
my problem is when i click to power up my pc the cpu fan spins for few seconds then stops and wont power up well i think its the cpu fan.. i can hear the fan noise like its powering up as normal.. ive opened up the case and had a look i can see the graphics card lights flash on.. some fans spin then nothing... i have removed the cmos battery for a few seconds.. switched the JP1 connector from 1&2 pins to 2&3 but still the same problem.. my specs are..
AMD FX 55 cpu
DFI lanparty UT NF4 SLI-D ( NOT USING SLI )
RADEON 1800 XT or is it 1900 not sure..
OCZ memory i cant rmbr the spec sorry...
600W PSU ( PCI EXPRESS i think the term is )
sorry im kinda outta date with the specs of this pc..
everything was fine this morning.. i shut the pc down. went out.. came back and now this is happening..
so before i go out and buy any new hardware i was wondering if the psu is dead ? or motherboard ? or if it can be fixed.. i know its an old pc but cash is kinda tight this time of the year...
i would be grateful if anyone has any ideas..
oh ive also tried a different pci connector to my gfix card as theres 2 with my psu
AMD FX 55 cpu
