- Jan 29, 2007
EDIT: That should read CPU temp, not system temp in the title..
Well, as I expected as winter is started to wan and indoor temperatures have gone up a few degrees I have seen my cpu temps increase 5-9C degrees over the last few days. This is not good news.
I am currently overclocking my CPU to 4.333 via the TPU and I am thinking I may need to turn it off during the warmer months.
I run BOINC for grid computing. Right now I am only running 2 cores at 60%, but I am seeing my core temps using Core temp software at maxes reaching 68 degrees. Whereas just last week they were just at around 60-62 running three cores at 90% 24/7.
I am a little bit surprised with the fan that I am using that I am not able to keep the temps lower than this. What can I do other than turn off the TPU overclock or change to water cooling? I have no interest in water cooling, I have no space on my desk. I was considering adding another fan to the other side of the cooler master to get a push pull effect, but from the information I am read online at most I am going to get a 1 degree differnece... Summer time indoor temps where I am can reach 34C. Right now it is only about 22C inside, in the summertime I think my CPU might go to 75-80C.
Am I at any risk of damaging the CPU for the occassional spike to above 70? Because I am only using 60% of the CPUs time for grid computing and not 100%, will that make any difference?
