Download Links:
EA Canada http://na.llnet.cdn.ea.com/u/demos/Crysis_SP_Demo.exe
NVIDIA http://download.nvidia.com/downloads/nZone/demos/nzd_crysis_spdemo.exe
Indirect Links:
http://www.fileshack.com/file.x/11333/Crysis+SP+Demo
http://files.filefront.com/Crysis+SP+Demo/;8895696;/fileinfo.html
http://www.fileplanet.com/168866/160000/fileinfo/Crysis-Demo-(Singleplayer)
http://www.gamershell.com/news/42876.html
http://www.gamespot.com/pc/action/crysis/download_6181835.html
http://www.4players.de/4players.php/download_info/PC-CDROM/Download/46497.html
http://www.worthdownloading.com/download.php?gid=1724&id=12977
http://www.3dgamers.com/dlselect/games/crysis/crysis_sp_demo.exe.html
http://games.internode.on.net/filelist.php?filedetails=12816
http://www.clubic.com/demo-jeux-video-6005-0-crysis.html
http://www.strategyinformer.com/pc/crysis/demo/18345.html
http://www.ausgamers.com/files/details/html/31644
http://www.fragland.net/downloads.php?id=15931
http://www.blogspan.net/1240-crysis-crytek-game-demo-fullspeed-download-u-simpleupload-link.html
http://85.25.140.65/index.php?option=com_content&task=view&id=37&Itemid=1
Torrents:
http://www.gameupdates.org/details.php?id=1743
http://www.mininova.org/get/961489
http://isohunt.com/download/28089542/crysis+demo
Tweaks:
So once you get it installed you are probably like "Ok lets see what this thing looks like" right... Cool so if your using XP and a DX10 card you are NOT out of luck, there is a so called tweak which can be used to force most of the very high settings to be used on XP/DX9. What you want to do is grab the info from THIS post follow those instructions and your set, you will notice a drop in frame rates, so its not recommended to that you use it unless your running 8800GTS 640+ / 2900Pro+. Cheers.
If you are interested in using commands in the SP Demo you will have to type this into the console (which you can access while in game by hitting the ~ button.) con_restricted=0. You should be set in that department since there are 1500+ commands.
Indirect Links:
Torrents:
Tweaks:
