- Oct 27, 2015
- Houston, Texas Area
- Thread Starter
- #21
I'm not too familiar with D5s but I believe the top portion of the pump is the intake so in your illustration, you're pumping water into the reservoir. If it was switched around it would be fine as I don't see any issue with the loop order as it won't matter since your reservoir is pumping fluid to your pump which is the most important thing and that it will reach an equilibrium, say after 30 mins of load.
Jack, you were right about the in/out on the D5 pump, I could have simply looked down at my own setup to see the mistake (it was late). Sorry I had to delete the illustration as it would have been a complete distraction from the intent and purpose of this thread to continue.
