- Jan 17, 2011
if someone going to ask why did i post this here and not on ps3 siite is because overclocking and cooling is a much more common task for pc so expect more accurate and expert answers here
i just bought a new Ps3 60gb ntsc on ebay.co.uk yesterday i will be doing this because want to avoid heating and the common yellow light of the deth (very common if not certain within a year more or less on this console version)
still did not receive the ps3 yet,these are my plans for cooling it:
the hard and maybe the better way change its heatsink with:
1) 2 big passive heatsink adding to them any way a fan each on rsx and cell,the fan will be mounted from the side not on top of the sink,so air will be thrown out of the console from the front window on the cosnole casing
2)still did not made my mind on choosing the above method or using liquid but that would have to take lot of elements like hoses,pump,radiators and reservoir ,consider that all those thing will be chosen on there shape and dimensions to make them fit inside the console and not outside,i saw there is some space on the top and in the bottom between mainboard and the glossy housing
3)changing the power supply to a aps-231 because it produces less heat than the one it has
4)applying external fans
Plan B the easy way:
doing just 3) and 4)
Questions:
1)will plan B be enough ?
2)from the pictures i posted what kind of adapters,coolers or opinions some of you would suggest
any opinion will be appreciated . . . but consider that all the coolers must go inside the console casing and i don't want to make holes in the case as somebody does,fans and/or radiators will stick on the console apertures but from the inside
Thanks
pictures are taken from the web
Questions:
Thanks
