Hello, I am planning to create a hardline build as a first time watercooler (no hate please - I am merely trying to go for the challenge). I am currently facing the issue of finding fittings that would fit 3/8 ID 1/2 OD primochill tubing. I noticed that primochill does not offer 90 degree fittings and I need compression fittings that are close to the dark nickel color provided by primochill's fittings. I am planning to do a bendless watercooling build because I am a big fan of the "lots of fittings" look.
I am also unsure how to do a drain port since I have a dual rad system with one rad in the basement. Do I add a drain valve on the pump?
My parts list so far is here: http://pcpartpicker.com/list/zm3K8K
Let me know if there is anything I can fix.
Keep in mind that I am somewhat of an amateur at watercooling so try and explain your answers in a way that I can understand. It would be much appreciated.
Thank you for the help.
