- Jun 8, 2004
Could someone quickly shed some light on the significance of AC vs DC pumps if any?
Phextwin said:DC pumps are more efficient; less heat into the water; lower temps.
Plus there is the whole convenience of dc and not having to play around with 110/240v 50/60hz setups and curves.
Veland said:...
Get the pump that fits your available space and has the right combination of head/flow for your setup, then give it the power it wants..
smokenjoe said:Yup get whatever siuts your needs pressure, flow, size and noise(if that is a factor). I wish that the mag3 was on that test I hear it can be a very quiet and reliable pump after you reinforce the seal.
zip22 said:"LOUD" isnt objective. for me the mag3 is barely audible with my ear against my case with my computer off (no fans, andything). with the compuer on, i cant distinguish it from anything else. its also cheaper than the mcp600 and eheim.
jamesavery22 said:Eh, compared to a MCP600 or a eheim 1048 that sucker is LOUD. And I did the blue RTV sealant mod. Is a nice and powerful pump though.
2Busy said:I cant reference actual sound against the Eheim or the MCP, but I can vouch that I cannot hear my Mag 3 from 3 feet away with the case open. And this is only over my fans at 7 volts. It is setting on a piece of foam, so there is no vibration. I can hear it when I first start it, and thats it. I cant imagine how any pump can be any quieter than this. As far the leak around the seal, might did not leak when I first started assembling my rig, but I decided to go ahead and seal it just to be safe.
