- Mar 7, 2008
I haven't built a system in a while, so wondered if I should try playing with an AMD box for a change. You might tell from my sig I might be slightly Intel biased recently, and I'm clueless about recent AMD CPUs.
Any tips or suggestions on the following:
Bulldozer core or equivalent - not important how many but 2 module/4 core would be plenty to play with.
Overclockable?
What mobo/chipset?
Low cost?
I just had a poke around some online stores, and if I understand correctly, there's FM2+ for APUs, and AM3+ for pure CPUs, which seem to have more cache. Is that right? So from a CPU processing power perspective, is AM3+ the way to go? I have spare GPUs and disks, so would only really need more ram, cpu, mobo, maybe PSU.
So for example, at 4 and 6 cores I'm looking at FX-4300, FX-6300, since there isn't much cost difference between them anyway, and the latter seems to have far more cache. The jump to an 8 core model starts pushing it into intel i3 territory which I'd rather get if going to that cost, so that's out.
Mobo wise I see 760G chipset at low end and 970 above that. Do I need a 970?
Overclockable?
What mobo/chipset?
Low cost?
