- Feb 19, 2010
Good suggestions here - I can say the fun you'll have tinkering with an AMD is worth getting into.
I own both and I still enjoy my AMD's vs the Intels, the Intels to me are...... Bland in that there's not a whole lot you can do with them vs an AMD.
With an Intel it's mostly just crankup the multi and you're off to the races.
With an AMD it's a little different with all the tweaking you can do, however the FM2/FM2+ setups are mostly like an Intel is now, BCLK limited and the same basics apply. I have a 7870K with a Crossblade Ranger and like Johan said, it's a good setup but tops out quickly.
An AM3+ setup with FX chips such as the FX-8350 and ran with 990FX chipped boards are whats fun to tinker around with.
Cheapest 8 core you can currently find new would be the FX-8300: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113399
And the best/cheapest board that will run it to it's potential is this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131874&ignorebbr=1
Or perhaps this one as the cheapest 990FX chipped board: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131851&ignorebbr=1
I only went with Asus boards since as far as I know they have the best lineup for an AM3+ based setup, I've certainly been pleased with my Asus AM3+ boards and just ordered another CHV-Z yesterday. Nothing wrong with the older CHV-Z I bench with, I got it for a DD build.
As for RAM, you'll have a hard time getting past 1866 unless you can find a good set of sticks and that's one of the major challenges with these - However if you do find a good set normally getting past 1866 and higher isn't a big deal once you figure it out - I can routinely hit or even top 2400 with mine but thats mainly due to the sticks I run along with how I tweak things.
Cooling has been brought up and yes - That is a big factor but you can still do OK with either the ready-made kits or even DIY watercooling like I have. It all costs $$ no matter what you do or how you go and I've chosen pieces that can be used with either so there is no "Loss" of the investment I have in them, can use them with both Intel and AMD.
EDIT:
I'll add that you don't have to invest in an 8 core, even the quads are fun to mess around with, the FX-4300 being the cheapest Vishy quad you can get. I also have one of those and just ordered with the new board a 4350 I'll be toying with as soon as it gets here.
However STAY AWAY from any of the 41xx or 81xx model chips, those are Bulldozer pieces.... However if someone just gives one to you that's OK.
The 43xx, 83xx or even the 9xxx chips are what you really want.
It's all a matter of what it's worth to you or how much you're willing to invest for trying it.
EDIT:
