I have looked at those fans, say on 7/5v how does it compair to say a delta 68cfm 80mm fan? If i ever got one i would have it so i could switch from 5/7/12, preferably pwm. I have found really loud fans keep my sister away from my computer, my mom well..um thinks the delta 68 is way to loud as it is. The first time i installed it and such she was like....why is your computer so much more loud? The only computers she has really been around are umm my systems with panaflows that i could hear the hd and nothing else or the 486's she used along time ago at one job she had. And you just know 386's and 486's really pump out the heat...heheh passive cooling works fine if you have any case airflow like say a psu fan sucking air in the case would be enough. Anyways, my advice is to put your pc on the floor, preferably put some sound deadening panels or somthing between you and the computer/headphones/earplugs etc so you dont go crazy from the noise or get headaches etc.
