I have the following hardware:
Motherboard: DFI Infinity RS482
RAM: 2x256MB Kingston HyperX PC3500
Processor: AMD Athlon 64 3000+ (CPUz says it's a Venice)
PSU/Case: Antec 430w PSU [from the Antec Fusion Case]
I'm experiencing two problems:
1: The system will not boot when I try to run the memory in dual channel mode. If I put the ram in banks 0 and 1, or 2 and 3, the system will not post. I have to put the memory in Banks 0 and 2 in order for the machine to post.
2: While running with the memory in single channel mode, the machine will lockup, sometimes even rebooting itself.
At first, I thought it was a memory problem (possibly bad ram) so I ran Memtest86 for a couple of hours. The machine eventually locked up, but there were no errors reported on the RAM.
I've reseated the BIOS chip. Well, seated it actually, considering that when I got it, the chip wasn't all the way in the socket. When I pushed it into place, the chip actually clicked in. I gained a bit of stability here, but not enough.
I've have updated the BIOS to the latest revision, which is dated 10/30. It was the same revision that shipped with the board, but I forced the updated anyway.
Instead of setting the ram by the SPD, I configured it to run as defined by Kingston (2.5-3.3.7). I recently read an article that said the tRAS value should be the sum of tRP+tRCD+2, which is 8. Since I have 7, I'll be trying it with a value of 8 tonight, but I'm not sure thats going to do much.
I've tried increasing the voltage from 2.6v to 2.8v to see iif a little more juice might help it out, but it didn't seem to help.
Last night I was playing around with CPUz and I saw that on the memory tab, it showed both of my memory sticks and it looked like they weren't running at the same speed. I saw something like this:
bank 1: 217 mhz, 2-4-4-9
bank 2: 200 mhz, 2.5-3-3-7
The timings that I'd defined were showing up for one stick, but not the other. I took a peek at the BIOS settings, and I found and option labeled Enable All DIMM slot clocks. When I cahnged this option to disable, it looks like it forced all the RAM to run at the same speed with the timings I set (200mhz, 2.5-3-3-7). However, it didn't seem to affect much.
Processor never goes over 42c. Tested this by running Prime95 and watching the temperature in the AMD Dashboard utility.
I experienced the lockup problem in Fedora Core 6, Ubuntu, Windows XP and occasionally in the BIOS screen.
I'm out of ideas! Here are my BIOS settings:
ANY help is greatly appreciated!
edit:I'm going to try this tonight, for grins, but could the problem be the RAM isn't as matched as I thought it was? Could one stick work fine at 2-4-4-9 and the other at 2.5-3-3-7? In which case, could I combine the timings for a greater success? Something like 2.5-4-4-9?
I'm new to playing with these settings, so be gentle.
Code:
DRAM Timing and Config
CAS Latency(tCL): 2.5
min RAS active time (tRAS): 7
RAs to CAS delay(tRCD): 3
Row Precharge Time(tRP): 3
Row to Row Delay(tRRD): <auto>
Row cycle time(tRC): <auto>
Row Refresh CYC Time(tRFC): <auto>
Read to Write(tRWT): <auto>
Refresh Rate(tREF): <auto>
Write to Read Delay(tWTR): <auto>
Write Recovery Time(tWR): <auto>
1T/2T Memory Timing: 2T
Read preamble Timing: <auto>
Async Latency Value: <auto>
DRAM Drive Strength: <auto>
DRAM Drive Strength Ratio: x1.42 <default>
DRAM DQ Drive Strength: <auto>
DQS Hysteresis: <auto>
Read and Write Queue Bypass: <auto>
Dynamic Idle Cycle Counter: <auto>
Idle Cycle Limit: <auto>
Bypass Max: <auto>
odd Divisor Correct: <auto>
Dual Dimm: <Auto>
Disable Jutter: <auto>
Digital Locked Loop: Enabled <default>
DRAM Bank Interleaving: Enabled <default>
Burst Length: 4 beats <default>
Enable all DIMM Clocks: Disabled
MTRR Mapping mode: Continuous <default>
PDL Delay Adjust: <auto>
DRAM ECC Feature Control: <disabled>
