for this board since it supports the 4 volt memory feature...
I want to find the fastest memory for this board since it supports the 4 volt memory feature... Currently running 4 x 512MB sticks at DDR400 333Mhz... Would I be able to use DDR667 or higher if I overclock the motherboard? Thanks!
A litle bit late??? Better than NEVER
The fastest DDR(1) ram for that sistem is the DDR600.
I bought this summer 2x1Gb DDR500 3-3-3-8 Xtreem by Teamgroup, some time before bought also the same set but 3-4-4-8 timings.
there is no way to run 4GB on my SLI-DR, tried everithin, every slot change, every sane voltage/CPC/remapping/timings/...
Those are probably either Micron -5B D/-5B F or Samsung UCCC.I bought this summer 2x1Gb DDR500 3-3-3-8 Xtreem by Teamgroup, some time before bought also the same set but 3-4-4-8 timings.
Recommended voltage is between 2.6 and 2.85, I'm running the first set @500 V2.7.
Actually on the bay there is an auction about 2x512MB DDR600 Patriot running V2.91 as shown in reported screenshots.
Much rare but present sets of 2x1GB DDR600!
The voltage of 4 is absolutely crazy, I think some crazy OCer could set that value to run common DDR400 or 500 to 600 and above but U know the life of ram is counted...
Just make a google search about sets of DDR600 U will find many.
Sorry if I came out so now but only a few weeks ago I decided to OC my Opty180 on DFI SLI-DR and 2x1GB DDR500.
Now I'm Rock solid @3000 (FSB250x12 V1.41) and DDR500 (FSB 1/1) 1T.
By now CPU stay regular at 40°C even gaming.
No reason to change system, may be GPU.
I'm looking on a DFI LanParty Venus SLI-DR expert for sale to test all 4GB of ram because there is no way to run 4GB on my SLI-DR, tried everything, every slot change, every sane voltage/CPC/remapping/timings/...
I've got two Opty180 to test so...
So the problem is to run 4GB in DDR500 may be different timings but they are so many that I dunno what to try.
But I don't know if it would be a great solution to run 4GB of ram, I red many forums in wich people get best results with a DR instead of an expert or a venus.
The only difference from a Venus and an expert are only SOME capacitors, the difference between expert and DR are digital SLI switch and mobo design/ram position. That mobo costs 100EUROS!!! without shipping...
If you have suggestion to help me run that 4GB, I know they are very good and a little bit different.
The problem is that I red also that with 4GB of ram the default speed is 333MHz, all over this is an overclock???
