Mike I apologize once again, its 5:40AM and I have not even eaten but at about 2pm this afternoon. Just got the I875B up and running, still working on others behind me. Going to bed now lol. But I PROMISE (these guys will tell you im pretty good about promising...just have to remind me sometimes!) I will walk you through it. The I875 manual is incorrect on how to do the USB.
Look at the USB header pins on the board. one set of pins has 5, one has 4. At the front (where there are two pins side by side), that is where your VCC (usually red) goes for both. The next pin is for DATA- (usually white), then the next pin is DATA+ (usually green), and the 4th pin is Ground. You will have one extra pin that is not being used (or its a 3rd ground...my Chieftech case has the 3rd ground, none of my other's do so there's always a bare pin).
If this is nonsense and you dont understand, have no fear, I'll cut a proper diagram when I get up =)
if you have USB headers on any other board, just look at them. They are all standard in how they connect. Its just an error in the I875 manual/setup sheet as I followed it too and thought the whole time "bs, this can't be right!" and blammo, it wasnt. So I hooked em up like all the other USB headers I have ever had to hook up, and they worked =)
T
PS: I875 "B" unfortunately only vdimm's to 2.9v =/
