First of all, first time poster and overclocker here. Here are my specs:
MB: Gigabyte Z370P D3
CPU: i5-8600k
CPU Cooler: Cyrorig H7
GPU: MSI GTX 1080 ARMOR 8G OC
RAM: HyperX Fury 2x8GB 2400mhz
PSU: Cooler Master G750M 80 PLUS Bronze
Now, there are two issues worrying me about my new OCed CPU:
1. Temperatures: at 4.5ghz, 1.35v, my i5-8600k peaks to 100c during Prime95 stress testing, then going down to around 80c (77c-83c). Then it peaks again for a while, like a cycle. This is the main reason I haven't run the test for more than 40 minutes, out of fear that the high temps will damage the CPU. I have also tested rendering an After Effects composition, since I know as a fact that this will be the most heavy use I'll realistically give to my CPU. The render lasted one hour and a half and temps never went beyond 85c, averaging at 75 the rest of the time. Then I checked the temps while running Heaven Benchmark and 3D Mark's Time Spy, assuming this would be representative of heavy gaming, which will be the most common use for this PC. Temps never went beyond 80c, averaging at 70 the rest of the time.
So, should I be worried about these temps? Specially the 100c I get during Prime95 stress testing. This is one of the main reasons why I don't up the voltage, which would allow me to get stable 4.7ghz.
2. Frequency: I had read that it was very easy to get 5ghz on these CPUs, so I was expecting to get at least stable 4.8ghz, but even at 1.45v, one core always fails (the same one every time), other than that, everything works well at this frequency. What am I risking if I decide to run at 4.8ghz in this scenario? Also, did I just get a really bad chip or should I assume these limitations are because of my MB and/or CPU cooler?
Btw, when I use EasyTune, I can get stable 4.7ghz with the voltage set on auto, but the stress test temps worried me, so I just set it to 1.35v in the BIOS and sticked to 4.5ghz, which is stable at this voltage.
I look forward to learning a lot here. Thanks for your time
EDIT: forgot to add that this is the first time I have installed an aftermarket CPU cooler and I'm worried the bad temps are because I did it wrong (didn't do the x pattern thing).
CPU: i5-8600k
