- Thread Starter
- #41
Wow I have not heard of that from anyone else. On my Gigabyte motherboard the default fan speed of the CPU at 64c is 1800 RPM and 75c 1950 MAX RPM.
When you manually set the CPU fan speed calibration does it work fine? The case temperatures like you say are slow to change.
Sounds like it might be problem with the PWM of your fan on the CPU. Or the controller is a problem, can you switch the CPU fan to Voltage control or try PWM? see if that will work.
Do you have the latest BIOS update?
Yeah, I have the latest bios as far as I know, but I'll check again. I can change the fan to voltage control, I'll try it and see how it goes. Thanks
