pull everything out of the mb. take some 91% rubbing alcohol to the area that you drooled on(feels silly typing that lol). pour it all over the pcb and sata port that got wet. if you see dirt etc coming off of the mb continue to pour alcohol on it until it comes off clean. dry it of with paper towel as well as you can. take canned air and blow out all of your ports. stand it up so that the sata ports can air dry for 24hrs. slap it back together and see if it will boot and shutdown properly. if not you know for certain its borked. for future reference you should never try to boot a system that got wet until you rinse the effected area with alcohol. usually once you power up a wet component its gone for good. you may get lucky with this one being that it will at least boot. GL
