- Mar 21, 2006
- Eindhoven, The Netherlands
I've had the TRUE 120 for quite a while now, used it on my E6420 mostly, however, I am now using it on my 2500K. The 2500K is Oc'd to 4.7Ghz @ 1.345V. The highest Idle temp I'm getting( core 1 and 2) is 44C, core 0 and 4 are going about 10C less. At full load(coredamage) the setup tops out at 75c on core 1 and 2 and 66c on core 0 and 4. To me, this seems a bit high for the TRUE and I'm wondering if something might have gone wrong mounting(remounted 4x now already).
I use the asrocks own mounting solution to mount LGA 775 coolers to 1366 sockets, but for some reason it bolts on too tight( on my previous LGA 775 board I had to put a dime between the mount and HSF so that it was bolted on tight, however, I cannot fit anything between it now? )
Anyone else run the TRUE 120 with a 2500K? what are your temps?
