- Apr 29, 2010
- Central FL
Just curious on what people use for air cooling on modern CPUs. Can they even be properly cooled on air without having a turbine engine of a fan? It seems I mostly read about AIO and custom loops these days.
I think you might be missing the point Earthdog and Wagex are making though. A D15 would be nothing like a stock cooler. The issue isn't the cooler's Max TDP capabilities, it's because of the higher heat density of the increasingly smaller CPU dies. This creates a physical bottleneck to removing heat rapidly. The best liquid coolers can help with this, but it's really more of a problem with the physics.
Going forward the industry will be tasked with creating more efficient cooling methods. One such method could be microfluid cooling, another could be mainstream TEC coolers.
No need to go anywhere... this is a forum and a discussion!Anyways.. didn't mean to rock the boat fellas, Ill see myself out.
On paper, modern CPUs don't have any higher TDP. Because TDP has gone to mean something different. TDP, on Intel, is the base clocks. Intel's boost clocks, (PL2) are a lot higher than the TDP. This chart is with a 95W CPU, for example.because modern cpu's don't have any higher TDP than cpu's a decade ago.
The heat pipes sit directly over the core. That hasn't/doesn't change
The problem is the physical size of the silicon in getting the heat out. If all other things remain the same, the more surface area there is the more heat can be removed. To complicate things, the density of the silicon (node shrinks allow for more transistors in the same space also plays a role.
I think you missed what I was saying or I failed to say it correctly. With the small dies less of those heat pipes are actually near the core so not directly cooling it. I would think a nice big bank of fins with a fan blowing directly on them would be better compared to the side draft most coolers have these days which rely on the heat pipes to lift the heat up to be cooled.
The same amount of heat is coming out of the CPU regardless. So, IMO, it won't really matter. That said, I'm not a thermodynamist(lol)... so no clue.I think you missed what I was saying or I failed to say it correctly. With the small dies less of those heat pipes are actually near the core so not directly cooling it. I would think a nice big bank of fins with a fan blowing directly on them would be better compared to the side draft most coolers have these days which rely on the heat pipes to lift the heat up to be cooled.
I launched model rockets... though, that isn't relevant.
