I'm having some issues with the computer I built and I think it has to do with overheating, but I'm wondering what others think.
every now and then, but especially when I initiate a heavy task, my audio, display, and input all stutter for a less than a second, usually multiple times in a row.
This same stuttering problem happened about a year ago and it quickly got worse and I got a blue screen telling me the processor was overheating. I re-applied the thermal paste and reset my heatsink and the problem was gone.
I tried this same solution last weekend and the problem disappeared for a week but now has come back. I downloaded SpeedFan and it tells me that my CPU is around 84C average. I'm not sure if I believe it though because my BIOS CPU temp reading only goes up to about 62C. SpeedFan also tells me that none of my fans are spinning but they all definitely are.
62C seems pretty hot for my specs anyway though - do you think I need a new heatsink? Or is this problem more likely a driver/software issue?
Here are my specs, everything is about 3 years old now except the PSU which I just replaced a few months ago.
Motherboard: ASUS P8P67LE B3 Revision
Processor: Intel i5 25000K processor
Heat Sink: Cooler Master V8 180W
Graphics Card: EVGA GeForce GTX570
Power Supply: XFX Pro850W
Hard Drives: 2 Seagate 7200RPM Barracuda drives
RAM: 2 4GB Patriot Viper Xtreme DDR3
Case: Corsair Obsidian 650D
OS: Win 7 Pro 64bit
Thanks!
OS: Win 7 Pro 64bit
Thanks!
