- Mar 5, 2002
- Bellevue, WA
It would be nice if Microsoft or someone over at Neowin would create a tool to clear out some of the bloat every once in a while.
The best way I can think of would be to make a tool you install after a fresh install of Windows or after you install all your programs and set your system up the way you want it. Then, when you install the utility, it would create a log of your current system settings and set those aside as uneditable. As time goes on and more bloat accumulates in your system, run the utility and it will give you the option to delete dlls, reg entries, and whatnot that haven't been used in a certain amount of time since the original log or last scan was performed. Obviously, some files and entries are going to come up that you may want to keep, so it would have to be able to clean things out on a per file/entry basis with a deselect option. Optimally, it would be able to list what program or file each entry is attached to so you don't accidentally delete the driver for your digital camera that you still have but haven't used for a few months because of the often cryptic file naming conventions that are commonly used.
Kind of a CCleaner on steroids.
Just a thought, and I might want to brush up on my windows programming to see how feasible something like that would be...
