Super Nade said:Folks,
I'm getting sick and tired of having to reinstall Crapdows every 4 months or so. I'm quite sure many of you have faced this problem as well. The object of this poll is to identify causes which contribute to Winblows rotting over time.
Please post a brief note explaining your choice.
In my case, I believe Winblows, being connected to the net, is the cause of my problems. I cannot think of anything else. My system is rock solid stable as I survived a complete stage #1 Gentoo 2.6.12-r10 install !
On my benching HDD, there is no networking option and that has stayed relatively stable compared with my primary XP install.
One of the key assumptions I am making is that, we are quite intelligent, so, spyware/virii do not contribute to the issue at hand
I have been doing extensive testing in the last 3 years about this vary subject
with different PCs
I have come up with testing were i can stress the hardware to make a mistake in a short time so i can cache it.
Xp has a reporting system back to MS for up dates and repairs.
I have taken programing in college you cant fudge a programing tree,
it will always lead you down the same path, the harddrive and memory CPU motherboard does fudge. That is why without testing you cant find out what is going on with the data corruption
The new hardware is so complex the conceivable problems is beyond the Designers, that is why there are revisions
This has been my lonely crusade for 3 years.
The system i use for my xp stability testing is a system that came with windows ME and 2 years ago it was upgraded to xp. It's used in share group apartment rest stop, with internet access. it sees extremely heave usage. 0 problems, Internet Explore dose not crash when using the net. It does have EEC memory
like the rest, i use to think my system was totally rock solid.
I only found through deep extensive testing that different PCs do make mistakes, by carefully planing and testing month of usage in a 4 hour span i can get consistent results.
Then i changed my rocksolid hardware to see if i can improve it. I have been successful, HT off big improvement.
This testing is vary hard to do i wish more people could do it, so there would be hardware revisions.
My last thought i wish i could get my newer and faster systems as solid as that old pc with xp on it.
