Hi all,
i've got 2 Reserator v1 plus unit's in my loop, but this is not going very well.
Story:
I have added a second Reserator because i was able to pick it up cheap and it looks very awesome, it would also be nice if my temps will drop a few degrees.
I have added the 2nd Reserator behind the 1st Reserator , the problem now is that the water drops almost to the bottom on the first Reserator and the second one fills up until the top.
Also the flow-rate dramatically dropped.
i also have a extra pump in the loop (Swiftech 355) with extra XSPC top.
Loop: 335 pump --> HDD block x2 --> 240 RAD --> CPU -> MOBO -> 6990/6970/6970 in serie -> 360RAD -> Reserator 1 --> Reserator 2 --> back to the pump.
Is this because the reserator's have air hole in the top?
Is it better to make a serial setup?
Or is it better to create 2 loops?:
Loop 1:
6990+6970+6970 on 1 Reserator + Pomp and 360Rad
Loop 2:
CPU + Mobo + HDD's --> 2nd Reserator + 240 Rad. Can the pump of the Reserator handle this?
System Specs:
1x HD 6990 (Water)
2x HD 6970 (Water)
AMD FX 3850 @4.7 Ghz (Water)
Asus Crosshair Formula IV (Water)
2x Aqua Computer dual HDD Drive bay (Water)
Thanks Guys!
Story:
Loop 1:
Loop 2:
System Specs:
1x HD 6990 (Water)
2x HD 6970 (Water)
Thanks Guys!
