- Jun 17, 2010
- Marietta, GA
Well said Mor, well said. I totally and understandably agree with everything you said. Cheers, now I need to get out before I drink to much before the party.
Have a great night bro!
I'm not sure where 120.2 per chip came from, back when I was in every thread, my rule of thumb for recommendations was 120x1.5 per CPU, 120.1 per GPU, and round up...which actually works out to exactly what you recommend!
As you alluded to later in that post, that does rather dated these days. You'd probably be pretty close if you reversed those! 120x1 per 4-cores of CPU (HT doesn't count), 120x1.5 per GPU (120.2 for stuff like Hawaii?), round up, minimum of 120x2 (what's the point of less??).
Yea, but see, I can't resist the urge to put little modifiers in there ...
Clever "rules of thumb" are not my forte obviously, lol.
Did I read that first post right and you have your hard drives WC'd?
I must admit, I do not have a clear picture of the routing of this loop.
I have these HDD water blocks for 4 harddrives, 2 times:
http://www.highflow.nl/water-blocks/hdd-blocks/aqua-computer-aquadrive-dual.html
I will try to make a schematic drawing of the loop.
What necessitated cooling your HDDs?
Mostly silence, they would probally work just as good without having water running through it.
I'm not sure I follow. How does it make it quieter?
It's a closed "box" with isolation material, it also is mounted with rubber socket's so there is no vibration.
How long have you had this system and when's the last time you did some maintenance?
All your blocks, reserators etc have been compromised. I would strip the whole system apart and clean everything! I am sure there's more places with that "stuff" lurking around.
I thought those blocks normally flowed from the inside to the outside. Does flow direction not matter with those blocks?
But yea, you'll need to tear down the whole loop and clean. If it's in the CPU block it's everywhere else too.
