- May 23, 2002
K, this is something I might want to seriously consider. In the near future I'm gonna be getting a projector/or HDTV. I want to try to use this as not only my computer monitor, but also TV/DVD etc. However, I like dual monitors....no I love dual monitors!!!!
I would think this would be feasable, but I'm not sure how the VGA signal works.
My Idea/Question:
Design a box that accepts 2 VGA pluggins and sends out 1 VGA signal.
It will have off/on button (pretty sure I can make that), and 1 button to switch from video processing of the 2 VGA signals to 1 VGA signal, and lastly, just sending 1 signal strait through. The latter would be very simple to imlement...the former I'm not really sure.
If the projector is set to send out a 16:9 ratio imagine. Normal VGA signals are 4:3 or 16:12. I would want to have the video processor to take in the 2 video signals and send 1 VGA signal to a 8:6, with the top 8:1.5 to be black, as well as the bottom 8:1.5 (so shrink VGA signal 1 in half, and add black to top and bottom to fill the 8:9 half of the left side) Then do the same thing with the second VGA signal only offset halfway to the right. So this would look like a dual monitor setup on the big screen, and the videocard would function like dual monitors.
Input/Ideas, technical scematics very welcome!!!
*technical specs on VGA would be very nice as well*
My Idea/Question:
