- Dec 11, 2003
Is anyone aware of such of cooler if there is one available. I would really like to expell the heat out of the case in this fashion. Thanks
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10008694&prodlist=celebros
hope this helps looks tempting lol
"Image shown is for display purpose"
Its just the standard single-slot 4850. The picture they are showing is of the 3870.
We tried the Thermalright HR-03 GT, Thermaltake DuOrb, Coolink GFXChilla and Arctic Cooling S1 Rev.2 and every one of them fit without any problems at all.
There will be.
Less specific please.
I think a 4850 with 512bit is a silly idea since the 4870 already has it.. is clocked higher and comes with the dual slot cooler. All for just $100 more. No reason to waste time with the idea of 512 on the 4850. Only thing I can see is that if you want to use aftermarket cooling then it would be a good idea providing they don't include the cost of an already attached cooler onto it since if it retains the same type of thin fan cooling solution then it's just going to be a minor enhancement over the 4850 out now since the new one will simply have 512bit.
