- Aug 9, 2004
- Baltimore, MD
Dual 2.8 Xeons.....holy god. >< My friend has some ridiculously uber computer with this stuff. She does a lot of video stuff...would the Dual Xeons help a lot with that?
Audioaficionado said:See the top rig in my sig Wasn't luck but lots of hard work to dream, plan, earn the bux and finally build it.
Most pro video apps are SMP aware and benifit from dual CPUs.
Audioaficionado said:You can build a decent Xeon duallie for under $800 if you base it on 1.6GHz LV Xeons and the Asus PC-DL. Some guys are OCing them past 3GHz. This would be an excellent bang for the buck system.
Yeah too bad they only equal 5GHzKibo-kun said:Holy crap...now if only dual 3Gigs in SMP actually equated to one 6Gig. XD
pcsurplusonline.com is where people are getting the 1.6 GHz Xeons.AFIsoldier said:Where are you finding those Processors, and why in the heck is newegg, zipzoomfly, and 3 other better known stores out of stock on that PC-DL?
Twin_Turbo said:pcsurplusonline.com is where people are getting the 1.6 GHz Xeons.
I had to get my (2) PC-DLs from mwave.com
They are $180ea. Fedex 3day was $18 for 2 of them.
My first set is running at 16x155 @ default voltage (1.3V)
Audioaficionado said:I don't want to /high-jack anyone from OCForums but 2CPU.com has lots of threads on putting together dual Xeon rigs. It's where I got most of my info.
The MooseMod works on the 1.6 GHz LV Xeons also if you do the Vcore u-wire socket mod to 1.6V (1.56V actual). But you can't guarantee 3 GHz Prime95 stable with them. For complete stability, it seems 2.8 GHz to 2.9 GHz is the general range. I had a setup with the 2.4/533 M0 steppings running at 3.5 GHz but sold it to our lead software developer at work. So I built a much cheaper one with the $120 dual Xeons. Even the DDR was cheaper and it runs at 220 MHz without the need for any VDIMM mod. To be honest, 2.85 GHz is fine for me. Especially with the FSB at 220 MHz!Dc5e said:yeah, if you get 2.4ghz 533fsb xeons, you can do the moosemod (a simple jumper change only on the PC-DL board). I believe M0 is the best for doing this mod, I myself have D1's and am able to do it. Others with the same stepping have had worse luck.
Last time i checked 2.4ghz 533fsb xeons on newegg were ~$230
