Hello, name is bryan first time over clocking here!, from the help of a friend and some online reading.. this is what i've come up with
i've been monitoring temps with hw monitor.
Checking GHZ, with CPUZ
Running prime95
I know this is no shape or for 100% stable yet, as I've only been running prime for 2 hours, then I went and played a game of CS 1.6, and had no issues, computers been on for 4 hours, no issues, later on today when I get home I'm going to let prime run for some more time.
Now if some of you experts could tweak a little and give me some insight. I'd be happy. I've tried 4 GHZ, at 1.425VCORE and 191 BCLK, but I blue screend. and didnt want to push voltage cause it seemed high.
I dont know anything about VTT/QPI/dram, and was told not to change it for such a low overclock..
My motherboard doesn't seem to support PLL.
BCLK 181
Multiplier 22x
Speed 3.98 ghz (says the bios) CPUZ reads 3.8 ghz.
vcore is at 1.4V, I've tried stock 1.35 and inbetween so far everything i get it blue screens. 1.4 seems to be key here.
as far as memory goes I have no clue on what's GOOD, or anything like that this is just what was suggested to me for now
memory multiplier 8x
tCL 7
tRCD 7
tRP 7
tRasmin 24
Voltage 1.66
Command rate 1T
Now with this setup^
temperatures are
Idle
When prime is loaded, temps go up to about 80ish, highest was 85, but it doesn't go over that.
One thing I dont understand tho, is when prime is loaded it will stay at 3.8 ghz for a minute then bounce back down to 3.6, then every one inawhile it will go back up to 3.8, but when I'm only doing like a 3-5 thread prime test it sticks at 3.8 ghz
i7 920 C0
DX58so board
gtx 285 super clocked
Also have a hyper 212 plus cooler.
3x 2 gb sticks of Kingston kvr133d3n9 memory, I couldn't find the timing for it, although when I go to the bias stock timing is 8-7-7-7 1.5v I believe (could be wrong here)
now I dont know anything about over clocking really, I've read into it a bit, I know my way around a computer (built them for years) although i've never really done any bios stuff basically i'm looking for some help on what to change and how far and good stuff like that
Running prime95
BCLK 181
Multiplier 22x
tCL 7
tRCD 7
tRP 7
tRasmin 24
Voltage 1.66
Command rate 1T
temperatures are
Idle
i7 920 C0
DX58so board
