Dye recommendations please
Searching for "Deep Blue Dyelite" doesnt get you very far anywhere. But it seems that many places carry exactly what he used in a different name. Here is one place that sells "Deep Blue" UV Dye which I am 99% sure is the same thing. Then again the dyes at DD actually SAY Dye-lite on the bottle hehe. Im sure with research, both you and I can find exactly what we're looking for.
EDIT: The good people at Tracerline make UV dyes for automotive water and oil based fluid systems leak detection. They do sell a blue variant. It is Tracerline Clear Blue Extended Life Coolant Dye. Product number for the 8oz bottle is TP-3920-0008. I found it via their zip code locator in a store 3 miles from my location. Where will your tracerline UV dye be? ;)
I figured I wouldnt worry about dye... every time I would want to drain my system... I would have to keep track of that water... and its kinda expensive IMO.
I found some UV sensitive tubing... and since I am going to light up my case with UV's... I figured this would work well. Has anyone used UV tubing? I would like to know how effecitve it is, before I buy.
FrozenCPU has UV reactive PUR brand tubing, which I would imagine is pretty good considering PUR is a major water filtration company. Their tubing should last nearly forever.
