- Jun 21, 2008
Ok my setup is listed in my sig. when i try and rase the fsb higher than 237mhz my system just says: DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
here is my available bios settings:
cpu voltage: i have set to +.025 which reads 1.232v under cpuz.
memory voltage: i have left alone its set to 1.8v
nb/sb voltage: i have left this alone as well set to 1.55v
fsb voltage: also havent played with set to 1.2v
cpu clock: 237mhz stock is 200mhz i have an 11x multiplier
i cant seem to get past this point. this translates to little over 2.6
stock is 2.2. i want to get to 3
system ram frequency: 667mhz
pci: 33.33mhz which is stock.
pcie: changed from auto to 100mhz. doesnt help.
i noticed that in my manual it says that there should be an option for cpu multiplier but it does not show up in the bios, is this due to my proccessor? i just can figure out why it wont go any more no matter how much i pump it up or down. i really wanna hit 3ghz out of this thing. what am i doing wrong or am i just pushing this system too hard?
