- Nov 23, 2005
- Reading, PA
I boot in about 10 seconds as well.....
M Diddy said:Well, I decided to give it a shot.... Not that complicated for me as I deal with Mid Range servers on a daily basis and know my fair share about RAID.
I set up a 50GB RAID 0 and the other 125 to RAID one.... I'll let the pic speak for it's self.....
G2145 said:i updated to the intel matrix 6.1 and right clicked on the arrays and write back was disabled, so i enabled it on both arrays...hard to say if it was enabled before the update, but i could swear that it appeared to be.....anyways, here is my latest hdtach
ajrettke said:How is 1300MB/s possible? isn't SATA II limited to 3gb/s? in RAID 0 that's still 6gb/s which is less than 1GB/s, let alone 1300MB/s
emboss said:It doesn't even get as far as the sourth bridge. What happens is that the RAID driver (since it's all software) uses the system memory as a cache. I'm not 100% sure how HDTach etc measure the burst speed, but if it's in the usual fashon (utilising the read-ahead caching on the disk) then it's quite probable that it's hitting the RAID driver cache (since it's designed to hit the HDD cache), and not even going anywhere near the disks.
A similar thing happens if you configure hardware RAID adapters in a particular way (usually different to their normal configuration, since normally they focus on maximising throughput on many concurrent requests not sequential speed). You can get burst rates of close to 500MB/sec from an ancient clunker of a disk if the controller is sitting in a 64-bit 66MHz slot - even more if it's in a PCI-X or PCIe slot.
That said, I personally wouldn't bother with turning on writeback cache for a RAID1 or RAID0 array, especially if it's software RAID (like Intel's matrix RAID). You just end up caching the data twice - once at the OS filesystem level and once at the RAID driver level. In addition, you increase the chance of losing data (hardware RAID has BBUs for a reason ...). While it might make some particular benchmark numbers bigger, it'll probably very slightly slow down real-world performance overall. Writeback cache is really only important if you're running RAID5 or similar where it's expensive to do partial stripe writes. OTOH, if you've got hardware RAID, then you've got the RAM sitting there so you might as well use it: at one time last year I had a computer with 128MB RAM which had a RAID card with 256MB RAM
bing said:Tried HDTach, HDTune, Atto, PCMark05, Sisoftware Sandra, H2Bench all are showing similiar result that it is "a lot" better with write cache enabled.
Seems like all those benchies were "fooled" by this Intel's stuff, any idea for this noob on what is the better or best benchmark program that you recommended to "properly" benchmark and hopefully will show the "truth" ?
bing said:Spotted an Areca 1230 PCI-E with 1GB cache burst speed (cache to main memory without mechanical involvment) with lot of disks on RAID 0, which is still below 800MBps, what is this means ? Poorly configured one ? or Areca is a fake raid too ?
Variable2212 said:Hi There
first off id just like to say i came across your matrix raid thread yesturday and was amazed at the performance you got. Im in the process of building a new rig and was really torn on hard drives like wether to a raptor or raid 0 some sata drives. i got to a point that i was just going to get one 320GB seagate and leave it at thyat since i couldnt justify the cost of a raptor and the thought of losing all my data from a raid 0 worried me. Though now i see this Matrix raid which would alow me to have the benifits of raid 0, and still have some protection. I do have a couple questions though...
first off, roughly what percentage of the drive is considered fast? Im now planing on getting 2 250's (like you have ) and was curious what the rough max of that raid 0 partition could be before it gets into the slower part of the disk.
Secondly would it be possible to use a program such as norton ghost to back up the raid 0 partition onto the raid 1 partition so when the raid 0 fails and i lose that data, i could restore it again?
and thirdly this is just a question out of curiosity, ive read alot on raids and it seems like theres the people who say it is faster and the people who say its neglectable, does it really seem fast?
so my general plan would be to get as much as i could onto the raid 0 partition, since i dont usually have hundreds of gigs of stuff on my computer, and try to back up it all up on the raid 0 partition if thats possible.
Thanks alot in advance for your help and i look foward to hearing back from you
