Mangas said:Hi there, Im new at this raid thing and just last week ive decided to do it but ive done Raid-0 on the promise controller my question is there anyway of changing from Promise controller to de Intel Matrix raid without having to reinstall OS again?
fhpchris said:Four 320GB Seagate 7200.10s on the way, going to have fun with my P5WDG2-WS Pro and E6600
I think I will run raid 0 OS and raid 5 Data over the 4 disks...
hyperasus said:P5WDG2-WS Pro and E6600? I didn't know that MB would work with C2D.
NoVaGator said:This is a great thread!
Here's a noob Q:
I'm doing a Conroe build on a 975xbx board. My primary use will be be HD video editing.
I have one 74 GB Raptor and two 320 GB Seagate 7200.10s
My original plan was to put the os and apps (Sony Vegas, Photoshop, Illustrator, etc....) on the raptor, and all of the video data on the Seagates in a Raid 0. (I'm not really worried about the integrity of the data in the raid 0 setup because I'll have all of my raw footage on DV tapes.)
Then I see the matrix driver disk with the mobo so start researching...and now I'm undecided.
Thoughts? Would I be better off with the os/apps in raid? I really need all of the space on the Segates because HD files are so large.
richklein said:Do you make the raid array through the raid controller or is it made after the OS is installed with the intel matrix setup? Its a bit confusing to me.
richklein said:Is it worth doing this with either 2x 150 gig raptors, or the 2 x WD drives? Would there be a large performance difference between the two setups?
Xaotic said:The array needs to be configured prior to OS load, unless it is not going to contain the OS.
Xaotic said:The difference in access time should be quite noticeable, though STR will not be as much so.
Xaotic said:I finally got some initial, non tweaked, results on 4x 320GB disks. Had time for a single HDTach run on the OS array. Config is 80GB RAID-0 and 853GB RAID-5. STR is running between 180-200MB/s and Access Time does not seem correct. 8.5ms is a bit lower than I'd expect, unless it's either not reading disk latency properly or is hitting the cached data in this test. I'll try to hit more testing tonight.
Xaotic said:Matrix RAID, like most onboard RAID controllers that are bootable, has a BIOS ROM that stores some configuration data and boot settings.
richklein said:I thought the intel matrix raid software was a windows based raid "utility"? Is it a true dual raid enabling device, or does it trick the windows software to see it as two separate raid arrays?
richklein said:How safe is raid 5? If you lost an entire drive, couldnt you still lose the whole array?
bing said:The Raid configurations is stored within the disk itself, roll back few posts of mine, it was proven since I just changed/upgrade my mobo from 945G/ICH7R to P965/ICH8R, and the new mobo just recognized the Raid array and booted from the 1st time I hooked em up.
Heck, I even deliberately plugged em "randomly" at my P5B Deluxe mobo with has 6 SATA ports, port 2 and 6 while at old mobo they were at port 1 & 3. Nice eh ?
