Over 1.5v is just fine. I've seen guys on some forums run their memory at 1.75v for daily use without any issues.
Yeah, and Intel also technically doesn't support overclocking.
Chips are much stronger than people give them credit for.
I've been running a 3770K since launch with memory at 1.65v for daily use.And I've even given memory 1.9v while benching with no degrading at all.
Yes. I'd try increasing the minimum distance between the plate and motherboard.By "under each screw hole" do you mean on the back of the motherboard between the plate and the mobo around the little peg that goes through the hole? The screws don't actually go through the motherboard because the pegs that that screws go in to stick through the motherboard a little.
Try Gold Memory. You really need to see how everything does when run with something different, and sometimes results have been very different between GM and MT86.One hour of prime95 blend and 8 hours of memtest 86 with no errors. Weird weird weird. Apparently it needed tighter sub timings. WTF I guess alls well that ends well. Thanks everybody. I'll try this for awhile and see if it holds.
Each of its tests checks all the chips, but I've also seen certain tests show tons of errors while others never found anything with certain memory modules. I kind of remember that happening with MemTest86 ver. 3.xx and its first 3-4 tests, so to save time I just skip to the other tests, and any modules that pass them then get screened again by running all the tests on them.Gold memory failed on the first pass. I'm ordering the mushkin to see if my board likes it more.
EDIT: It's weird. Goldmemory runs without errors through test 289 and then as soon as it gets to test 290 the errors start adding up rapid fire by the thousands. The errors kept piling up at light speed into test 291 when I turned it off. Are the different tests checking individual chips on the stick or what?
Ah well it's too late now, the mushkin is on the way. I don't care if it's the best as long as it works at it's rated speed with stability. I just want to try another brand and it's the only thing on newegg that runs at 1.5v at a desirable speed that doesn't have massive heatspreaders that block heatsinks. I do kind of like the looks of that low profile samsung ram that everyone loves and may try it if the mushkin doesn't work out. I prefer the simplicity of xmp (if it would actually work). Prolimatech is sending me a universal backplate like the ones that come with the newer megahalems and they're sending it from taiwan for free so that's pretty cool of them. I'll be running the mushkin with a stock 1155 heat sink in the mean time. I'll check out that link you posted in a minute. Btw my ram passed goldmemory at 1600mhz, even test 290. I feel like if turning down the ram makes me stable it's a pretty safe bet that the cpu and the ram slots are ok. Unless I got a 3570k with a gimpy memory controller, but what are the odds of that? Then again I guess I'd believe anything at this point.Each of its tests checks all the chips, but I've also seen certain tests show tons of errors while others never found anything with certain memory modules. I kind of remember that happening with MemTest86 ver. 3.xx and its first 3-4 tests, so to save time I just skip to the other tests, and any modules that pass them then get screened again by running all the tests on them.
You may want to check these reviews of memory diagnostics: Part 1 Part 2
The articles are over a decade old, but apparently they remain the newest such reviews available. Notice how badly SIMMtester.com's DocMem performed; it's kind of famous for passing memory that other diagnostics say is really bad. And despite how well Gold Memory performed in that review, I don't trust any single diagnostic because I've had modules that passed one of them for hours and hours but failed another fairly quickly.
I wouldn't substitute G.Skill with Mushkin, unless the Mushkin modules had name brand chips on them and no heatsinks. I haven't bought Mushkin in a long time, but apparently it's not better than most retail brands, meaning it's not very trustworthy. I think the only way to always get top quality chips is by buying Samsung or no-heatsink Crucial modules.
