- May 7, 2005
you all are going to love this one ;D First headache was of my own doing. i didnt order enough rotary 90s to finish plumbing everything. so i had to reorder more. only took a few days to get more in. then one of these lovely xspc rotary 90s started to leak from the one attached to the bottom of my res. thankfully it was in a position so as it didnt leak on anything but the case. if your wondering where the leak was exactly it was where the rotary section is. it didnt always leak but if you moved the rotary around it would start to leak. i bought extra 90s just in case. so i drain the loop and refit new 90. woot woot lets get it runnin. reconnect everything. refill and leak test , everything is golden. then comes the much loved headache of connecting all of the components and hiding wires blah blah blah. couple of hours later everything is truly ready to go! hit the power button and NADA. motherboards onboard power button is flashing lightly green, 5vsb(white) and bios chip(red light) are blinking but ABSOLUTELY NOTHING ELSE is coming on. so i suck it up and call tech support. within 5 minutes ive got an rma number in hand. ty evga.
yesterday i was going thru the x99 classified section at evga and what do ya know, theres a thread chock full of people that have had similiar issues! annnnd theres a quick fix! apparently the io shield has longer than usual tabs that sometimes get pushed into the usb and network slots. if you pull the io shield you should be good to go according to those that have tried it, yes!. so i unpack the mobo pull the io shield and reinstall the mb... yeah you guessed it, no love. no change at all. oh well.
i was able to get the mb pulled and reinstalled without draining the loop. so again i pull the mb to find that my hand is getting wet! ANOTHER rotary 90 is leaking! holler for the gf to grab me some towels ahhhh! quickly wrap the cpu block up in a handtowel and finish pulling the mb out. i go back to the rotary and it looks like its actually leaking where the cpu block and barb meet. being absolutely pist off at this point. i make an ignorant mistake and snatch up a pair of needle nose pliers and begin reefing on the fitting to tighten it up and POP! the block cracks. happy happy joy joy. it WAS in fact the rotary that was leaking after all btw. anyone need the base to a ek supremacy? so here i am with a dead rig needing a new mb ANNNDDDD a new cpu block. kind of wish i was still a drinker cuz ah sure could use one nah. hahaha
good thing tomorrow is monday i guess, i can order a new block and get the rma shipped off and try try try to put this horror behind me!
