- Jul 31, 2003
- Los Angeles, Palo Alto, Lake Tahoe
Hey guys, been a while since I stopped by and checked in. Well if you guys remember, the mach I with R404 gas, still runs fine, then I had bought a mach II unit, and at the time, was debating the gas R507 on that one, well I ended up doing it, and replacing the fans on the unit, there is about a 20 degree difference between the mach I and mach II ( obviously the mach II being the colder of the two), I do say, that the mach II has a little more integrity in the construction of the unit. It has a better fan controller and more solid wire connections when you pull it all apart, and a tad bit larger compressor...although all this, I cant see where the extra dollar value is really being put into, just seems they corrected what they overlooked on the mach I units. So today the new vapochill lightspeed arrived via UPS, and I have just cracked it open and am staring at the bad boy now. Opening it up I can see it uses a compressor almost like the mach II compressor, the CPU "cell" seems a bit more reliable and more stylish than the mach I or mach II unit. It is heavier it seems than either though. Ill be assembling the killer rig in the next few days and should have it benched and what not ..by next tuesday. So far my conclusions about these three kings of cooling units:
1. Mach I has a 7/10 on construction and assembly, small things like wiring connections could have been a little bit better. Overall, the mach I with gas change to R404 , and replacement of the stock fans to YS tech fans, makes a HUGE difference, when I say huge I mean [email protected] and the LCD temp on the front reads -38/-40 on full load. For about 400-500 bucks (US), and another 100 bucks for the gas to be exchanged (or free if you got a AC friend), it can compare to a stock mach II unit.
2. Mach II gets a 8/10, could have a 9/10 if they didnt get gay and start charging for the LCD as a seperate part of the base unit...and didnt raise the price so much just cause they knew we'd pay for it. The construction is solid, the wiring is solid, the new compressor is larger and quieter than the mach I danfoss compressor. Stock temps on a [email protected] were about the same as the modded Mach I, or pretty close, full lload overclocked , temps were about -42/-43. After the R507 gas exchange temps are about -59/-61 on LCD probe, BIOS temps stopped reading accurately after about -30. I like the unit, its rigged , strong and solid, I still think they can HIGHLY improve the hermaphatic cell "heat plate" that goes on the back on the mobo a LOT. the wires they use are to frail, after a few installs and removals, it can easily break, Also If you remember I had problems with condensation ruining one of my mobos, I still cant decipher where it came from, but i wouldnt doubt it being the weak a** heat pad. Now on all my vapor cooled setups I use non conductive grease, inside the pinholes for the CPU and all inside the cells, but make sure not to let it come in contact with the seal string, cause it will weaken the integrity of the seal if it does come in contact.
3. Vapochill LS, seems to be the next dream come true, well just have to see...
whew I hope that wasnt to long...
