I iRevo Registered Joined Jul 8, 2013 Jul 14, 2013 #1 All my fan connectors on the mono are used up and the fan included a 4 pin molex cable. Can I know where do I plug this in ?
Culbrelai Member Joined Oct 25, 2012 Jul 14, 2013 #2 The power supply should have these, if you have a decent enough one there should be some extras available...
OP I iRevo Registered Joined Jul 8, 2013 Jul 14, 2013 Thread Starter #3 Culbrelai said: The power supply should have these, if you have a decent enough one there should be some extras available... Click to expand... But my power supply only has the 10 pin ones left.also there is no 4 pin connectors on my PSU. It is an antec hcg 620w
OP I iRevo Registered Joined Jul 8, 2013 Jul 14, 2013 Thread Starter #4 Ok I found a 10 pin adapter for the molex and it works now
