- Dec 14, 2010
Who the designed these things?
After spending a while affixing one of them to a fan I found out that when you put it on the push side of the fan you get almost no airflow coming through the filter, but the way these are designed that is the only way to attach them and have it look normal.
Also, they come with no instructions whatsoever, just a few box-shots on the outside of the packaging showing them attached to fans. So there's no real way to know how the manufacturer intended them to be mounted or used.
The only way to attach them and have it work to filter the air while not impeding airflow too tremendously would be to mount it outside the case, put the screw through the case and into the holes of the fan on the inside using the case panel like a gasket of sorts between the fan and filter grill attachment piece. It will look ridiculous, but at least it might work that way.
Also, interesting fact I learned today, it is easier to pull air through something (like say a fan grill or filter) than it is to push it. I had sometimes wondered about this, and as it turns out my suspicions were correct.
